Atlee
Jan 16, 2014Explorer II
I'm not sure what you are referencing here. "EMS= Energy Management System.. This system tries to keep you from tripping a 30 amp park breaker if you are on 30 amps.. Basically does nothing if you are on 50"
My Progressive Industries Energy Management System (EMS) Model # EMS-PT30C provides:
1) High/Low Voltage Protection, 2) Time Delay for A/C Compressor, 3) 3-Mode Surge Protection, 4) Surge Indicator, 5) Reverse Polarity Protection, 6) Open Neutral Protection, 7) Open ground Protection, 8) AC Frequency Protection, 9) Accidental 240V Protection
Mine is for a 30amp system. The EMS-PT50C is for 50 amp systems. My PI EMS does more than try to keep me from tripping a 30 am park breaker.
wa8yxm wrote:
There are several devices that your subject line can referene.
EMS - Energy Monitoring System: This monitors incoming voltage (And current but that's for your info) and displays them, SHould voltage, and in some cases frequency or waveform, fall outside of a specified range, they shut you off to protect you from bad power. These will protect you from a power SURGE (long lasting over voltage) Brownout (Low voltage) and usually contain spike suppression.
Surge Guard: an RF surge guard is the same as an Energy monitoring System, However those outlet strips also sold as surge guards.. Are Spike suppressors. A true surge and they alert you (Sound like firecrackers going BANG on July 4).
Voltage Regulator: I think you mean Autoformer, This is a device which depending on the make and model attempts to protect you from Brownouts (low voltage) By boosting as needed.. Or in at least one case that as well as HIGH VOLTAGES by bucking the voltage a bit.
In your case.. You said "in-house EMS" Which leads me to suspect that it is the Energy Management System..
These systems display AMPS if you are on a 30 amp site and may display Volts as well, they will have indicators to indicate if you are on a 30 or 50 amp site and possibly a way to specify a 20 amp site.. They can control air conditioners and possibly the water heater cutting them off if you need power elsewhere.
Hope this helps.
