rk911
Mar 10, 2015Explorer
a residential fridge uses 120-volts AC, not 12-volts DC. the amp draw should be on a label in your manual or on the fridge. but, an amp is an amp is an amp. if you're using an inverter and the fridge pulls an average of 5-amps per hour (just an example), the inverter will pull 5-amps from the battery cuz that's what the fridge calls for.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
