dougrainer
Jul 27, 2015Nomad
Winne/Itasca used to have a switch on the dash labeled MOM/DUAL. To charge the coach batteries when driving, you MUST have that switch in the DUAL indent. Does your Model have this switch and is that switch switched to the DUAL side? The MOM is spring loaded, but the DUAL side will stay indented in that position. The DUAL side supplies 12 volt power to that charge solenoid/relay. Doug
