CloudDriver
Jul 27, 2015Explorer
kmb1966 wrote:
Thank you all!! I have ordered the part. Awesome help here!
If the part you ordered is the one in my previous post, be advised that it is a little larger than the Winnebago one. In my case, the space available in the compartment was tight and I had to do some playing around to get it to fit. It's also fun working with the heavy, stiff 12 volt cables in a tight space.
Stating the obvious, make sure you disconnect the ground cables on both house and chassis batteries before doing anything else.
