kmb1966
Jul 31, 2015Explorer
Update: No voltage at the center post yellow wire when engine is running.
No voltage at the battery boost wire that should be hot when the engine is running. bottom wire hot, middle hot when button pushed, top wire no hot. this is the wire that is supposed to run to the center post of the battery solenoid.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
