kmb1966
Jul 31, 2015Explorer
Final update: Problem solved. The problem was a FUSE (15amp) on the fusebox next to the steering wheel. Fuse was for heater/blower which this wire is tied to. According to the drawings, it is supposed to be this way. Replaced blown fuse and problem solved. coach batteries being charged while engine is running.
Thank you all again!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
