Ok , I'll admit when I am wrong and post it publicly and subject myself to a curmudgeon's derision.  No offense Mex :)
I rescind my claims that the pins and sockets of my new junkyard connector were pristine upon reinsertion and that Stabilant 22 is a good product for this application.
deoxit vs Stabilant22But for those who don't click links:
Stabilant is more solid and requires re-application if the connection is disturbed or changed. This becomes very important in high vibration applications (equipment and systems with moving parts, transportation, aviation, etc.).
My Caig kit arrived yesterday, and last night I decided to clean the dirty 14 and 60 pin connectors on  the Older ECM.
First I used the CRC QED cleaner to remove all dust and old grease. I even used a bunch of q tips and very small pieces of cotton cloth held with precision tweesers to really get the connectors free of all visible dirt and contamination. I buffed the pins with q tips saturated with the QED cleaner. Man oh man they appeared clean under 565 lumens of LED light, and a magnifying glass,  but perhaps a little rough.
Then I sprayed both sets of pins with a light shot of Deoxit spray, the 5% stuff and set it aside.  I came back with Q tips after 5 minutes or so and buffed the pins
I went through about a dozen q tips as they first turned grey, then black as the pins went from rough grey/white to polished oily silky smooth chrome as I twisted the q tip back and forth buffing the perimeter of the pins.  I did this until the q tips did not darken but stayed pink from the De oxit spray.
The Brass pins on the 14 way connector were not as oxidized and did not need as much loving to become clean and silky smooth, but I figure the new junkyard connector could have dirtied a dozen more q tips after I QED cleaned it, and foolishly and publically declared it pristine.
I still believe the solder joints on the circuit board are compromised, but I will certainly be treating everything, every connector, ever switch, anything electrical which can oxidize with these Caig products.
yesterday i twisted by hand a small screw inbetween the 2 connector halves, and have not had a stall since. Rains and swell has kept me from applying Deoxit to the semifunctional ECM in my Van as of yet, but soon.
Examples of success so far.
The spray has stopped my 3.5 stereo mini plug cords, from phone/mp3 player to stereo from crackling when moved or twisted. They join and unjoin better than new.  I can swear my stereo sounds better too.  It is so so much easier to insert the plug into the phone, and it just feels right.
My turn signal lever, lately, was requiring more and more pressure to get past the Detente where it holds on its own.  I was afraid other lubricants would cause issues if it got on the electrical contacts. Getting deep inside the steering column for precision lubricant application was too much effort.  I sprayed the general area of springs  cam and contacts with DeOxit.  Now it takes half the amount of pressure to move the signal past the detente, and it does not disengage with a loud clank when the turn is completed.  The signal indicator illuminates with much less travel and pressure than before. And this improvement makes driving round town much more pleasant as sometimes I feared breaking the lever to get it past the cam to where it would hold on its own, and would hold it just before the cam to indicate a turn.
Apparently some got on my gear selector lever too as that now turns easier.
I Sprayed on my Phone's micro USB connector, left for a bit and excess wiped off, It now takes half the effort to seat the connector, and it feels like new again..
I used a Q tip to clean a 14500 Li-ion battery top and bottom and the receptacles inside a flashlight with rubbing alcohol, as I have always done.
I then sprayed some deOxit on a Qtip and did the same thing and it came off battery black, and another qtip  came out of flashlight black.
I have 2 90 degree RG6 connectors to my TV, which is on a swing arm. Sometimes when I move this swing arm the tv loses a strong channel and needs a little manipulation to come back. A few sprays of Deoxit on and in the f connectors and this is no longer an issue.  I suspect there is also a signal increase but cannot verify.
I'm simply too impressed with this product.  My kit came with 3 small bottles of Deoxit, the Gold and the Shield, along with small tubes of 100% concentrate as well as wipes and some application tools.
I'll be ordering a larger can of deoxit Spray, because I am going to go over every connector everywhere, and my little can is already half gone and I am looking at more and more things I can use it on.
