randallb
Dec 28, 2014Explorer
You had a couple or more injectors leak down over the storage period. If you want to clean your injectors, etc add 1 quart of cheap, available at certain sources for $2.90/qt, ATF/20 gallons of gas and hit the road. Run that tank out and fill it up again and it will run much smoother. ATF is a lot cheaper than "injector cleaners" and does the same or a better job.
Randy
Randy
