path1
Dec 28, 2014Explorer
Right after getting our class C I used Seafoam and it worked great, maybe too great. It really freed up stuff in gas tank, and of course that got caught in the fuel filter, once filter plugged then 2 injectors got plugged up. Then after cleaning out injectors and another new fuel filter, it plugged up the filter again (about 3,000 miles) I changed filter again and then again in another 3,000 miles. Now after 10,000 miles it runs great. I ran Seafoam thru it when mileage was around 100,000 miles. Old owner (Cruise America) apparently didn't waste much money on fuel system cleaner. And apparently the gas is not as clean as the advertisements we see. It runs great now and I run a injector cleaner about every 6 mo. No particular brand but I always make sure I get mixture right.
First I would see if one of your coil over plug got some water in it. Maybe it will dry out after some exercise. If it still does it and if no codes being thrown I would change fuel filter to see if that's the problem.
The injector place where I took my plugged up injectors to tells me that he loves Seafoam. As it brings him customers. By the way I like Seafoam now (even after my troubles) because it really did clean stuff out.
