ernie1
Dec 28, 2014Explorer II
Thanks everyone for their input. The suggestion that one or more of the injectors had dried has me thinking. I park the rv inside a garage so I don't think water in any of the ignition would be an issue. I have several containers of Techron and will try that simply because I already have it on hand. If that doesn't take care of things I'll go the Sea Foam route. Again, the problem only occurs for a short while like 5 minutes after initial startup and then after that, things smooth out. Once on the road, the problem does not reoccur.
