ernie1's avatar
ernie1
Explorer II
Dec 28, 2014
Engine running rough after storage
Just started the v10 engine on my 2005 PleasureWay after it had been sitting for about 4 months and it ran rough for about 5 minutes and then cleared up and was smooth running after that. I understand all the concerns about gas with ethanol which will stratify and needs Stabil added( which I did) etc. What I am wondering is whether any of you who experience this adds anything to the gas tank like Sea Foam to help clean the fuel system including the injectors while driving and whether it helps. I would add the Sea Foam as something curative rather than preventative since I'm already using the Stabil. If you do use the Sea Foam, what version would you use? I understand there's different types.
  • I use Lucas fuel system cleaner. It works awesome. Run a few tanks and it smooth's out and the MPG goes up usually a couple.
