my electric entry step keeps running (clicking) after the step is all the way out clicks around 5 times and stops.any ideas what to check? thanks, hoffy
If it clicks when retracting And when it extends High probably of broken teeth on the main gear in the gear box, And you will need to buy a new gear box for your step, it will work as is until too many of the teeth break, which could leave you in a situation where the step does not retract all the way and keeps clicking until you will power
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
