my electric entry step keeps running (clicking) after the step is all the way out clicks around 5 times and stops.any ideas what to check? thanks, hoffy
Which Brand step do you have? If Kwikee---BAD MOTOR. If LCI(Coachstep) it is either the pie shaped drive gear(missing teeth which you can see) or a bad motor. PS, either brand should NEVER click. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
