jodeb720's avatar
jodeb720
EPDM roof Material or Something Else?
I remember reading this a while ago - there are two types of roof's installed on RV's. EPDM and something else.
I know 2Oldman is the king of all searches - but I'm not that good.
I remember the way to differentiate was the coloring on teh back.
Today I pulled one of my vents off and found the color on the a "blackish" color. Which roof type do I have -
And as long as you're reading this.. What adhesive do I use to reattach a replacement piece to the sub-straight base?
Thanks
Josh
  • 3 tons wrote:
    ...So it’s not quite clear to me why one would seek to avoid TPO??
    3 tons
    Unfamiliarity, and not enough knowledge on the subject.
  • jodeb720 wrote:
    OP here -
    First thanks to IAMICHABOD that link told me I have an EPDM roof - Now the follow up question - what adhesive is the correct one to repair a section of the roof?
    Thanks!
    josh
    How big of a section are you needing to repair? If it's a tear, get Eternabond tape. If it's a small hole, the I would use Eternabond and then Dicor self levelling.
  • I got a pinhole last october and by the time I had found out about the hole, I had a bubble (like the top of a 747) of the 5er.
    Since the Trailer is 12 years old - for the time being i just want to reattach the existing roof (except for the single hole - the roof is in decent shape) the existing EPDM back the wood substrate.
    As Doug Pointed out in another email - because of the age of the 5er - If I was going to do it right, I would replace the entire roof - but for the time being I need to seal it up so I can use it for the season.
    So my question is: What is the correct type of adhesive to use to attach epdm to the wood substrate of the roof?
    The ONLY CORRECT way to attach a TPO/EPDM roof to the roof is to pull the OLD off and redeck(overlay) the existing wood deck. Then use EPDM/TPO approved adhesive. If you attempt to install new TPO/EPDM over the existing wood after removing the old, the new glue will not adhere correctly to the old decking and you will have hundreds of little bumps under the new roof material. Below is the link for the adhesive. Doug
    PS, Use the link and use that glue to do your repair. What I do for your type is to cut out the square area and remove the rubber. Cut a slightly larger piece of rubber and glue in place and then use Eternabond around the perimeter.
    https://dicorproducts.com/product/water-based-bonding-adhesive/
  • dougrainer wrote:
    snipped
    THAT is why I like reading your posts. As simple as it is I wouldn't have thought of doing it that way but it would definitely work better than what I would have done.
    I would have cut a slit at the bubbled part, laid it down flat and put Eternabond on the cut part to seal it. I still wouldn't have the repair glued down doing that, even though it would be sealed.
    I am also a lousy carpenter. ;)
  • Doug,
    As always, thank you so much for the guidance and advice.
    I was thinking exactly the same idea for resealing it after it was reattached.
    Eternabond, and once it's all together (with new wood underneath) I was going to put one of the roof coatings (hengs, henry, etc) - of course, not knowing which one to use, If I'm in for an inch, I'm in for a mile. I'll ask.
    Which has been the best performing coating that you've used?
    Thanks!
    josh
