weejumper's avatar
weejumper
EPDM Roof
Going to clean my EPDM roof. I see so many products recommended to clean and condition the EPDM roof. I am curious what the pros use? Chime in this forum and let me know...
What do you use to clean?
What do you use to condition?
  • I use Murphy's Oil.....put in bucket with water,,,,,wash with brush as used on sides,,,,,works wonders. I use it all the time...GREAT STUFF....
  • Plane old soap and water is best for cleaning and EPDM does not require any conditioning. My product of choice is "simple green". What DOES need attention is caulking on your rubber roof (same as with metal, fiberglass and vinyl roofs). Inspect it and do repairs before cleaning. EPDM and other roofing materials almost NEVER leaks but caulking does.
    Good luck / Skip
  • water and scrub with a soft brush the roof is over 20 years old and still works.
    Easy the REAL PROS use ABSOLUTELY NOTHING ... it's not needed and probably shortens the life if you clean it.
    Larry
  • I use a mixture of dish washing liquid, bleach, water in a yard sprayer. Spray it on, leave it for a few minutes then spray it off. Go over stubborn spots again, sometimes with a soft bristled brush. The manufacturer of the motor home said no conditioner needed. It is a good idea to spray the plastic vents and covers with a uv protectant such as Aerospace 303.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
