MEXICOWANDERER's avatar
Aug 30, 2013
Equalizing Formula (We'll Use A Pair Of Golf Car Batteries)
You need to get an accurate hydrometer. Without one you are blind. Might as well trying to determine if a person has high blood pressure by having them stick out their tongue.
  • Disconnect negative cables from 12 volt side
  • Fill all cells with distilled water
  • If you have a PARALLEL set of batteries, unparallel them:Wait overnight
  • Measure voltage across positive and negative terminals of EACH battery separately. It does not matter if they are 6 or 12 volt. MEASURE and write it down!
  • If a pair of 12 volt batteries differ by more than .3 volts or one 6 volt differs by more than .15 volt note which battery has what. Low batteries need more careful inspection
  • Charge each battery at 10 amps until every single cell in that battery is bubbling. Stop the charge then go on to the next battery
  • It's better to charge 6 volt batteries independently rather than in a series pair
  • With all batteries fully charged let the battery temperature return to normal
  • Hydrometer test each cell independently
  • Write each cell down. A diagram figure showing cells is the easiest way to remember
  • If you draw a sample and the electrolyte is SMOKY cloudy end of test for that battery. It's doomed. Same for a reddish tint
  • Do all the cells
  • I do hope you are wearing safety glasses and latex kitchen gloves right? You do have a ready made up jug of baking soda mixed with water, right?
  • The hydrometer bobber MUST float freely within the glass tube. Tilt the hydrometer upright to let the bobber run up and down freely
  • Did you remember your reading glasses and fit them under the safety glasses?
  • Every cell on your diagram should have a number next to it.
  • If any two cells in one battery have a .15, that's point one five difference between the highest and lowest cell, it's due to be equalized
  • Cull that battery from the bunch and MARK the low cell with a marking pen or splotch of paint or whatever
  • If you have a pair of Golf Car batteries that each have a .15 spread in density you may consider connecting them in series just like you have them in the coach to make 12 volts.
  • Take your time! Make sure they are connected in series!
  • A pair of golf car batteries can be charged at 11 amps. This is not easy to achieve nor to sustain but do the best you can
  • Amperage will drop and voltage will rise as the equalization process continues
  • When a series pair of batteries reaches 16.0 volts stop the charging. Go to the next battery or batteries and let the first ones cool off.
  • This is why record keeping is so important
  • Repeat the exercise on the 2nd set of batteries.
  • If you are doing a single 6 volt battery apply 11 amps until 8 volts is reached
  • Redo the hydrometer check.
  • If any cell did not return to 1.275 or 1.280 you have a troublemaker on your hands
  • If the battery is fairly new and had been abused, repeat the 11 amps equalization charge
  • If the battery is more than 3 years old it's dying.
  • How soon it's going to die is anyone's guess, but batteries that do not recover fully are not up to doing full task work
  • The harder a battery is to equalize and the faster the cells become unequal in gravity the closer it gets to the recycling center. You can count on it.
  • Harbor Freight sells an inexpensive 500 amp adjustable load test machine. I love it as doing a load test alongside a hydrometer inspection and equalization is a great dose of truth serum.
  • Get proficient doing this and charge fellow RV'ers to do their batteries. No one else does this right so you'll be the exclusive agent in your area.
I hope to get a 3 amp VARIAC soon. They cost fifty some odd dollars and with a VARIAC I can play a charger like a pipe organ. Maintain 10-11 amps with precision.
My fingers are aching. I hope this becomes a sticky. I would get censored if I wrote what I think of arthritis.
  • Hi,
    Are they temperature compensated? If not, they come under the heading of "toys".
    It is also possible to use a Refractometer
    Refractometer
    Michael in MN wrote:
    How accurate are the $5 and $10 float type hydrometers?
  • Thanks Mex, lots of good info there.
    I don't know how doomed is doomed though. I saw smokey and then I didn't see smokey. I know it is down there lurking, but if it doesn't come up every time, you can ignore the first time you saw it, right? :)
    My "previously enjoyed" T-1275s have been worked up a bit at home with alternating Equalize and Recondition (pulse charging that does not raise voltage)sessions using the VEC1093DBD charger.
    They were mostly near 1.255 all cells when "found," but after four days of nursing at home, they are mostly between 1.260- 1.265 with one cell on one battery at 12.75. No smokey.
    I have not done a new load-test, but have them back in service at our camp site. I feel confident in these batts. They do everything demanded in the way of high amp draws and recharge well.
    I don't know how many deep cycles we do a year, but I am thinking these two-year old beat-up batts could last us the rest of our RVing time (we just turned 70) based on the number of cycles per year we manage. (Not counting the shallow cycles under solar that we do in the summer---are they even "real cycles" against the cycle-count limit?)
    There hasn't been much discussion of T-1275s. New they cost near $275 each and weigh 82lbs. So a pair is 300AH and 164lbs for $550
    Four 6s (232AH) at $175 each at 67lbs is $700 for 268lbs and 464AH.
    Three T-1275s is 450AH for $825 and 246lbs. So three T-1275s is sort of like four 6s except they cost more.
    They do high inverter loads better in that they have less voltage drop towards the dreaded 11v inverter alarm. It makes an interesting choice between three T-1275s and four 6s until you can get those 6s for half price at Sam's or Costco.
  • MEXICOWANDERER wrote:
  • I do hope you are wearing safety glasses and latex kitchen gloves right? You are wearing a plastic apron or a garbage bag with holes for the arms and neck, right? The little spits of acid that you can't even see make little holes in your shirt (damhik).You do have a ready made up jug of baking soda mixed with water, right?
  • Thanks. I would add the step above.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 09, 2026
