skidooman93's avatar
skidooman93
Erratic Tank Sensor Readings
Does anyone have a fix for erratic tank sensors. I have one grey tank sensor, and the black tank sensor that cant seem to give consistent readings. The coach isn't very old, 2014 im the second owner.
  • Check out SeeLevel.
    http://www.bestconverter.com/SeeLevel-Gauges_c_108.html
    Dusty
  • Normal in any rv. You can tell when they are getting full without the sensors. The black will make small burping/belching sounds and the grey would make the drain slower and then back up in the shower.
    Try a dose of Walex Commando ... I do a couple of times each season and have no tank monitor issues at all. :B
  • I searched "erratic rv tank sensors" on google and got basically nothing lol
  • Search here or google "The Geo Method". Discussed here at least 10 times a year. Basically, Dawn blue and Calgon with water in a tank slicks things up and rinses the crud off the tank walls.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
