Shadow_Catcher
Dec 31, 2013Explorer
There is NO substitute for having a battery monitor that tells you via a shunt what is going into and coming out of your battery volts and amps and knowing the SOC. Trimetric or Victron.
There is also no substitute for a VOM/multimeter and knowing how to use it to check connections and voltage along the way.
Looking at Go Power and their 'kits' it is clear they are clueless about voltage drop, using 10Ga wire and including 50' of it...
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
