westend
Aug 23, 2015Explorer
For final cleanup, use Acetone or Alcohol instead of mineral spirits. ISTR, a poster stated that the Eternabond Preparation product is primarily acetone.
You must use a roller with a good amount of pressure to break the encapsulated adhesive within the tape's matrix. Roll it good, using a small roller with handle.
The tape should roll over that arch. Lay a piece of tape with the plastic backer still on before proceeding and see if it buckles too much. If warm out, I think the top vinyl layer has enough give to make the bend.
Good luck on the taping, Eternabond is a great product.
