MrWizard
Aug 23, 2015Moderator
look in the paint and wallpaper section of your local hardware store
you will find rollers there
get one with a wood roller or a steel roller, do not get a rubber roller
you need a hard roller one that does not give, you need a hard surface to do the job right
and roll firmly
your hands will be tired, maybe achey, when you are done
if not you did not roll hard enough
eternabond needs good hard firm pressure to make the adhesive seal and bond correctly
and roll firmly
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
