MrWizard
Aug 25, 2015Moderator
Joel_T wrote:
Seems it offers the best of both worlds of sealing and adhesion. Wouldn't it be good for helping secure AND seal roof mounted solar panels. I'm using well nuts through the feet though.....can't roller that area. Will finger pressure around the well nuts be enough to activate whatever it is that needs activating?
NO..because of trying to roller it to make it adhere
but you can use 3M VHB tape strips, between the mount and the roof
stick the mount to the roof with the VHB, then but a couple screws thru it
top the screws with some sealant to keep them from vibrating loose
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
