Bill_Satellite
Feb 23, 2019Explorer II
rockwind1 wrote:
i've got 2 water tanks, both made by Aztec, and both are cracked. tried plastic welding and it just doesn't work.
IS THERE ANY DIFFERENCE BETWEEN FLEX SEAL TAPE AND ETERNA BOND RV ROOF REPAIR TAPE?
has anyone used either to repair a small leak on their water tanks, i think i have 6" wide tape so there would be plenty of overlap.
has anyone compared the 2? i almost think this flex seal guy is just remarketing eternabond tape
Flex Seal products STINK (not my first choice of words). However, it's also unlikely that Eternabond will also solve your cracked tank problems. You are going to need a new tank to solve your problem. You "might"be able to find someone who does plastic welding and do a full weld on the crack but it's likely that event this would be a short term solution.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
