landyacht318
Sep 09, 2014Explorer
Maxed out at 15.27V ( at output terminals) and 37.5 amps when I had ~220 watts of lighting load and ~75% charged AGM battery for it to feed.
37.5 amps read on 'gt power" rc power meter, AND clamp on DC meter.
Fan is not very loud, but is very restricted by small openings in aluminum case
Case is getting pretty warm now, especially the side which contains the voltage pot. Kind of smells. Smelled soon as the fan started turning, before it got hot. Will probably dissipate.
"10 gauge" wiring to battery switch is warm.
Terminal voltage 15.27, GTpower voltage reading 15.07. battery monitor reading 14.8, so I am suffering good voltage drop on the DC side, but this is just test mode.
It is not going back!!
Okay time to reduce voltage to 14.6 for this AGM.
Whohoo, adjustable voltage. PD Iota and powermax can all kiss my keister!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
