landyacht318
Sep 11, 2014Explorer
With regard to the POT, 2 of the 3 pins are embedded in the ground that goes to the V- output terminal.
When dialed fully clockwise for full voltage there is no resistance.
When dialed fully Counter CW for minimum voltage the OHMS read 0.872 k OHM.
I'll recheck the blobs at the base of the caps. Since it is the same color of the thermal grease I assumed that is what it was.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
