landyacht318
Sep 14, 2014Explorer
Definitely Aluminum. I tried to scrape off the tinning, couldn't, and also it is way more flexible than even the finest stranded copper I have come across. It says 12 awg on it, but I believe the diameter to be closer to 14awg
Also, for some readers who intend to use this as a battery monitor, there is a load and source side, so it only counts current flowing in one direction.
2 meters and some simple math are needed for monitoring amps in AND out of a battery.
It will however power up the display with voltage hooked to either the source or load side of the leads.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
