landyacht318
Sep 15, 2014Explorer
I had set the voltage at the terminals to 14.70 volts, and then plugged it in to the battery. i did not touch the new Pot during the test at all.
I measured the CW terminal voltage in the beginning and twice more 5 minutes apart.
............It was 14.31 20 seconds after start up and making 38.09amps
5mins later It was 14.14..........................and making 38.89 amps
5mins later it was 14.24..........................and making 39.74 amps
4 minutes later I noticed amps had risen to 41.24 amps and the buzzing had changed tempo. I was in the process of getting ready to record more measurements when I noticed amps had dropped below 36. and it was still buzzing and the amps were dropping quickly. I reached over grabbed the IR gun turned around and Poof Crackle crackle Psssst fweppp. Flashes Smoke and Flame that quickly extinguished itself. Not really that much smoke or flame. I did not even open the doors, my regular ventilation was enough and I can no longer smell that usual horrid magic blue smoke.
It was kind of neat seeing the flames through the fan hole.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
