mena661
Sep 16, 2014Explorer
The MegaWatt units go low enough for float charging in hot climates BUT don't do that magical 16V that some of you guys need. I've used mine down to 13.00V.
landyacht318 wrote:I'd want the same but in a unit that does 80-100 amps.
Ideally, I'd like a user selectable 15 or 40 amp max charge rate, fully adjustable voltage up to 16v, and a built in timer that triggers a user selectable float of 13.1 or 13.6v.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
