landyacht318
Sep 17, 2014Explorer
I knew it was a smart phone 'Migrate'
My 31, was about 55 to 60%SOC, amp hour wise if it were still new, yet it was able to gobble 38 amps for those 17 minutes before the magic blue smoke release.
I have about 3 feet of 10awg to about 11 feet fo 2 awg to my 31. I've got some 8 awg on the way. but even when i put my clamp onmeter rght over the battery cable by the battery I was reading 36 amps when meters closer were reading that too.
The dropping to 20 amps in your phone dictation say your battery was much closer to 85%+ when you applied the megawatt, or the megawatt is Limiting current by 1/3, or your battery is not as healthy as you believe.
if it was at 60% when the MW was applied, the MW unless limiting itself it should have done 30+ amps for an hour or more,likely more. Have you another method to check your ammeter for accuracy?
I watched some U tube videos on the less expensive meters on Ebay and amazon, and even calibrated to the limits of the calibration pots, were way off still.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
