MrWizard
Sep 20, 2014Moderator
The Logic of trying to keep a constant 30+ amps of current eludes me
Constant voltage is what I Want to see
The current will follow depending upon battery resistance
A constant low amps at peak voltage at the end of cycle for full top off I understand, but trying to force feed one battery 60+ amp hrs in two hrs, I do not ..!
I know there are limits and there is voltage drop, and the voltage will climb to the set point
I want to see the voltage climb to the set point and stay there .
I know the amps taper, I don't try to force feed the batteries for a specific time period
Of course I have more batteries, I would need a 210 amp charge rate to do 30 amps per battery
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
