greenrvgreen
Sep 21, 2014Explorer
FULL AMPS ON MEANWELL SP-200-15
Even though I bought this unit to charge a 100ah-160ah bank for tenting, I did the following experiment using my much larger (660ah) TT bank.
--Turned off shore power to entire TT
--Ran 5a AC load (600w) from 660ah battery bank through inverter
--Hooked meanwell to bank and applied 14.8v from 200w unit (400w net loss).
--Plug Power ac meter reported steady 2.5a-2.6a AC draw into meanwell.
--When batt bank V had depleted into 11.8V area (load was exeeding charge by ~400w), I cut the inverter load but left the batts isolated, charging only from the meanwell.
--40 mins later, AC amp draw has edged up to 2.7a, batt bank V continues to climb through 13.9V.
--No sign that the meanwell has any issue with this treatment. Certainly no sign of shutdown or hiccup protection.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
