jrnymn7
Sep 22, 2014Explorer
i too have been twiddling with a voltage pot; in my case on my modified pm4b-75; and i too have noticed a quick drop in amperage at start-up... throughout the soc range... perhaps this is just the norm for units with no soft-start capability?
and i've been using the pm for half-azzing a top/eq charge on my two 215ah banks. it maxes out at 16.47v boost and 15.42v abs. so a little low for a true eq, but good enough 'til i can do a real eq with the psu i ordered.
i have a question though, regarding amps during top/eq'ing, and not sure if there's a thread dedicated to such? i series-wired the two batts which have one bad cell each, and hit them with 15.42v for 5 hours one day, then 3 hours the next day.
??? i have noticed the amps rising from ~5a to ~9.5a after a few hours of steady 15.42v charging. is this normal? and the resting battery voltage dropped from 12.81v (pre-15.42v charges) to 12.72v afterwards... even though the sg readings went up and helped eq the two bad cells a little? (after doing another top charge with my nautilus 15amper at 14.95v, to within .01v drop, the resting voltage returned to 12.81).
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
