JaxDad
Aug 26, 2018Explorer III
time2roll wrote:
Collectively the instant change is impossible. Convert 10% a year and all will adjust just fine. BTW a 20 amp circuit is needed for 16 amp max charging so there I just cut 20% off the required load.
No worse actually than coming home on that hot summer day and all 600,000 turn on their A/C at the same time. The utilities are actually eager to supply all the transportation energy.
16 amps gives me a maximum of 13 kilometres (7.8 miles) per hour of charge, in 12 hours that would be just 150 km (94 miles). That’s a best case scenario. If I had to depend on that nightly I’d be walking to work if I had to do any additional driving during the day (I often do an extra 100 km 60 miles during the day) or went out during the evening.
A 10% per year conversion rate? So you think they’re going to upgrade the grid every year? Hmmmmmm, I suspect not.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
