PartyOf_Five's avatar
PartyOf_Five
EV Charging station & RV use
It seems that electric vehicles have a couple standards for charging stations but the ones that are free (like Volta) likely have a J1772 plug. It'd be great to just get 30A out of it. Anyone seen any adapters, or tried any products?
  • If you can figure out a way, I think the first thing you should power up is your moral compass.
  • Yes generally 208 or 240 volts. NO neutral. Need to feed a transformer with a split phase output for RV use.
    Need to communicate with the pilot signal to avoid pulling too much power then the supply relay will close.
  • If you figure it out I suspect you should prepare yourself for charging station rage....heh
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
