BFL13
Aug 17, 2021Explorer II
Also check the floor at the front for water damage. A friend had that on the front wall and it turned out the front part of the floor where the front wall joins up had a 2 x 4 along there that was soaked through and it was all just a mess. Big DIY job I helped with.
If the Rv is still under warranty let them get at it including the front floor area. If you need your rig for camping, consider renting an RV instead of not getting that work done. It could be ugly behind that front wall all the way down.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
