dougrainer
Aug 18, 2021Nomad
Listen I have FIRST HAND knowledge of both lemon and legal areas of your type problem. 42 years worth. DO NOT LEAVE THE RV. people think that if they just leave the RV it helps them in a legal case. It does NOT. The OEM and possibly the dealer will be making notes that while you have a problem and the leak is sealed, it does NOT keep you from using the unit. If you have no use or trips, then leave it, but just leaving it and then try to state the problem kept you from using it will not hold water. Doug
