NinerBikes
Jun 13, 2015Explorer
landyacht318 wrote:
I plan on acquiring a Lifeline g31-XT from them next week, and hopefully later, for myself, a Trojan J185, also known as the T-1275.
The T-1275 Plus has individual cell caps that are hinged, for access, versus a 3 cell cover cap FYI. So you have options, although the T-1275 does not have a carry handle integrated into the design, so keep that in mind for access to cells vs how easy or hard it is to install it into the location you have planned, if it's kind of tight access.
These cells, BTW, are Mofo'kn heavy, darn near 90 pounds each, wrestling them into place if you are an older gent could wreck your back, so be careful and respectful, no twisting your back while installing and use your knees to lift.
Double check that J-185, perhaps you mean a J-150?
Linky
Another thing I noticed is that the J-150 is almost an inch wider than a T-1275.
Trojan battery product specs
