MEXICOWANDERER's avatar
May 31, 2016
Excellent Value 120vac DPDT 30-Amp Relay
http://www.mpja.com/05-31-16.asp?r=386312&s=2
Stock No: 32886 RL
$10.95
Availibilty: In Stock Units: 197
This is the relay I used for Quicksilver. Two relay COILS can be connected in series for 240 volt operation. EACH relay contact is rated for THIRTY AMP continuous service. One relay can be used for 30-amp shore power/generator auto transfer. Two relays can provide dedicated 30 ampere 240 volt service. One contact EACH relay for neutral. Breaker EACH relay neutral for 30-amps.
For X-tra heavy duty service I used double relays for 30 amp shore power.
Compared to most relays I have seen in modern motorhomes these guys are light-years superior in capacity and longevity. Contacts are silver-cadmium flashed, and connections are flat blade screw.
The price is one-third to one-fourth that normally found.
The fishing vessel Kelley II, uses EIGHT of these relays for high amperage 3 phase 4-wire, shore / generator power.
  • Tom_M wrote:
    smkettner wrote:
    I like the small cover.
    OK it is twice the price but 50a rated.
    http://www.ebay.com/itm/NEW-50A-DPDT
    Nice relay but coil voltage is 120 volt DC. Adding a diode to the coil voltage may work.
    I think most of the control modules with delay have the diode.
  • brulaz wrote:
    Tom_M wrote:
    I purchased one of these from Grainger
    120 VAC 30 amp DPDT power relay
    If I'm reading the specs right, the spring held NC contacts on this only have a 3A rating. Guess you need the strength of electromagnet to hold the NO contacts contacts closed to get the 30A rating?
    Good catch. I must have assumed that the NC and NO ratings would be the same. I used this relay to transfer between inverter and shore/generator power. My 300 watt inverter is connected to the NC contacts so I lucked out.
    WARNING. If you need 30 amps for both the NC and NO contacts, don't buy this one.
  • I would like to lay eyesight on what's inside a "Progressive Dynamics" transfer switch. The relay.
    Yes this relay is "Old School (like me)"
    But it makes a rolling-on-the-floor joke out of those .250" Faston connector relays as is depicted above. Like comparing a Wiha screwdriver to a Glorious Revolution Hero Factory No 32, screwdriver.
    My primary objective is to Make It - Install It - Forget It
    Utter reliability.
    And NO and NC contacts need to be mused over. Shore power demands NC and guess what? NC contacts are "The Weakest Link". Or are you trying to convince reality that a generator normally supplies more amperage to your rig than a power pedestal?
    Relay voltage threshold chatter is only a problem if amperage is broken and remade in the power contacts. Are you trying to tell me you spin down a generator with power load circuits loaded down?
    The relay CONTACT area mm sq of the large relay dwarfs that of a plug-in relay. Or does anyone want to argue the point that the duty-cycle ability of a tiny relay equals that of a large relay? Quicksilver was built in the years following the outfitting of the Kelley II. I DID break-down and clean the power contacts with De-Oxit D100 the last visit (whether they needed it or not).
    Meanwhile I am going to order some relays. And Yes, I do use SCR and solid state DC relays. Try and find one that lasts 30-years :)
  • Hello,
    how can I purchase one of these relays please call me @520-347-9103 thank you my name is Mark Rial my e- mail is atlastpainting1@gmail.com
    • way2roll's avatar
      way2roll
      Navigator II
      You are responding to a post that's 8 years old.
    • opnspaces's avatar
      opnspaces
      Navigator II
      We haven't heard from Mexicowanderer in years. Hopefully he's still alive and kicking. But yeah as way2roll says you most likely won't get an answer to this.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
