MFL
Feb 27, 2021Nomad II
I agree, he put way too much grease on the spindle, and the seal will push it off in that area.
I think he was trying to demonstrate how to turn the wheel, when using the grease gun on the EZ lube. However, after doing a proper hand greasing, there is no need to add more through the zerk. You should be good for several years, before any further greasing, if no brake symptoms occur, requiring hub removal.
Jerry
Jerry
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
