RustyScupper wrote:
Batteries are good. Swapped in new ones and same result.
Beemerphile1 - that is what I was suspecting. Does the whole unit need to be replaced (fuse/breaker panel) or can the "converter part" be replace.
Almost always you can replace just the converter itself and leave the distribution panels etc. intact. It may require a little bit of creativity in mounting, or perhaps even installing a separate converter that is deck-mounted elsewhere.
Bestconverter.com is a good place to start looking for what you need; they're reputable, have good tech support, and have decent prices. Many people here favor the Progessive Dynamics converters with the charge wizard.
