Andonso
May 14, 2018Explorer
It would be less difficult and costly to just add a couple more breakers using a breaker box.
Unless I remove AC (Air conditioning) which is rarely used and uses a dual 20 amp breaker. I can add a 5 and 10 amp breaker using a breaker box or possibly one 10 and one 15 amp breaker.
I could combine the two (freezer and converter) into one breaker but would prefer the converter and freezer have their own separate breakers.
I sometimes use the sheds power strip that the freezer plugs into for other power such as e.g. an electric tool, pressure washer.
However since the AC is rarely used I'll probably use it's 20 amp dual breaker one connection for the coverter the other for the freezer which doesn't use more an 5 amps.
The AC unit I'm thinking of removing and installing a skylight with air vent.
