dougrainer
May 15, 2018Nomad
road-runner wrote:My 30 amp rig came from the factory with the microwave and water heater on the same breaker, and the refrigerator is on the same circuit as the power converter and 4 outlets.
dedicated appliances, fridge, microwave, AC HWH etc. are required to have their own seperate breaker.
Unless you have not found it, MOST quality built RV's can have the Water Heater and the Microwave on the one breaker. BUT! That means the OEM has installed a Switch(either manual or automatic) that allows just 1 of those 2 to run. You cannot run both. IF you can, then they made a mistake on build. Doug
PS, just because an RV HAS IT DONE, does not make it correct or safe. THAT is why they have TSB's and Recalls.
