myredracer
May 15, 2018Explorer II
Andonso wrote:myredracer wrote:
What are you working on and trying to accomplish?
I lived in a RV full time for more than 25 years. The one I'm currently in is designed for travling, iirc it's a weekender. not really designed for full timing.
What is your load requirement? More circuits for intermittent, seldom used loads or for say electric heat in the winter & higher demand than normal? A lot can be squeezed out of 30 amps depending on needs and 30 amps can be run continuous at 30 amps (unless a pedestal breaker is tired) and in fact can be run over 30 amps for a bit depending on how much over and for how long (it's how breakers work).
