BFL13
May 23, 2018Explorer II
I don't understand "ground continuity" but I am no electrician. All the DC fuses are for the positive wires in a circuit, the negatives go to the neg buss.
All of my DC fuses (except the RP 30s)in the 5er were 15s except ISTR a 10 for the Winegard TV panel. This MH has all 15s. There are other DC fuses and breakers of higher amps here and there away from the DC fuse panel.
The AC breaker size in amps "goes with" the AWG of the wire going to that breaker. If the question is for the 120v input to the new 75 amp charger, it needs #14 and a 15a, but you can use #12 and a 20a to play it safe. It almost does need 20a. It is borderline by code. The PD 80 amper does need a 20a.
