Andonso
May 24, 2018Explorer
Well I found all my dc lighting and bathroom fan plus some other equipment that uses DC.
The only 12 volts DC I actually use is the rv lighting and the frig. The only other 12 volts I've used while full timing is the 12 volt cig. lighter outlet once in a while.
My micro is on a separate circuit. My water heater isn't originally gas/electric, has 400 watt (AC) rod that installed that plugs into an AC outlet. It's thermostatically controlled and only on if the water drops below a certain temperature.
