AFHauler's avatar
AFHauler
Expectations for 6 volt batteries
We replaced our two 12V group 24's with two 6 volt golf cart batteries - 220 amp hours. We also have 270 watts of solar, a Trimetric monitor and a Progressive Dynamic 9100 converter with a Charge Wizard.
When we first go into the trailer the monitor says the batteries are at 13.4, which is fully charged. Within 4 or 5 hours the batteries are down to 12.5 and this is after using only the water pump, a few LED lights for a couple of hours and the fridge (on propane) - no furnace.
What can we expect using these batteries? When we had our 12V's we could go several days, even using the furnace and that was before we had the solar.
  • I assume you are in full sun. Measure the voltage on the solar controller input, then on the output.
    I assume 12 volt nominal panels but post the controller model if you have it.
  • KJINTF wrote:
    x2 something is wrong
    How about a few more details
    We might be able to venture a good guess as to what is wrong
    What other information will be helpful? We'd love to get this figured out.
  • x2 something is wrong
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
