Flapper
Sep 24, 2013Explorer
My error - I noticed the clock after I plugged it into shore to recharge. It likely wasn't on when just on battery.
Thanks for the rough estimates of expected powered down (but not off) life. Kind of what I was assuming. And, unfortunately, kind of what I was assuming about what I did to the battery....
The silver lining - I wanted to get a type 31 AGM as a replacement anyway. Now I have a reason to dig into the details of the built-in charge system to make sure it will properly charge an AGM. Or I install the spare high end dual channel trolling motor charger I pulled out of my boat last year, and put in two 31 AGMs!
On a slightly different note, there is a master power switch in the battery compartment. Would be nice to have a sub-master in the main switch panel inside, that cuts off everything except the emergency brake and the jacks. Sounds like a nice retirement project next summer...
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
