ktmrfs
Dec 14, 2015Explorer III
6v GC have higher signficantly internal resistance and hence voltage drop than do 12V starting or marine or for that matter deep cycle batteries. 750W load is around 60-70A, a pretty good load for a pair of GC.
Here is what I and some others have found with GC batteries. Once they get below about 80%SOC, a load in the 750-1000W range WILL very often trigger the low voltage alarm on a inverter and have a voltage in the 10.5ish range. The fact that it rose to 12.5 volts w/o a load is IMHO a good indicator that the batteries are probably around the 75-80% SOC and you just found the reason that those who draw 75+ Amps from a battery bank either go with mutiple 12V or a bank of 4 GC. It also doesn't help that you were around freezing. AH capacity of a battery decreases at low temps, and internal resistance rises. All going in the WRONG direction if your trying to get a big draw from GC batteries.
So.... before you get real worried, get the batteries FULLY charged with a good charger, measure the SG on each cell. Good chance what you will find is that you know the main drawback to GC batteries.
4 GC with 550AH capacity won't give the cranking amps that I get out of a puny 70AH 12V starting battery for my diesel.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
