ktmrfs
Dec 14, 2015Explorer III
BFL13 wrote:
There is more to battery usage than high current draws though. Golf cars that do that are in various iterations. 6-6s for 36v, 4-12s for 48v, 6-8s for 48v, and whatever.
I like 6s for easy recharge to true full after successive 50-90s. 12s are a bugger for that! :( I don't mind the extra voltage sag with high inverter draw, since I am set-up to deal with that. Solar doing daily 80-99s might be better with 12s, not sure. AGMs are known better for low voltage sag with high draws, but have their own "issues."
What you have to do, to get it right for your own camping situation, is read this forum for ten years, do a thorough analysis, and then flip a coin! :)
yup, you hit the big points on GC and the others. Important thing like you mention is there is no ONE right answer. Depends a lot on what you need.
Like you I have 4 GC, do lots of dry camping, like/need to draw them down well below 50% SOC, and want long cycle life. Usually am only drawing 5A or so, And work around the high current draw issues with careful planning and 4 cells.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
