BFL13
Dec 15, 2015Explorer II
The other question is whether it is worth the bother to do a recovery when you can buy 6s in the States for $90 each instead of $180.
Before they can be treated "normally" again they need to be recovered properly which is a big effort and maybe not possible for a busy person.
I get about 0.8 drop on my four 6s with 110a of load. So to stay above 11v alarm I need about 12v going in for the drop and a bit left over for actually running the load for a few minutes. A PSW inverter would want more like 150amps to run the same MW, so that would make for a bigger sag, so you would need 12.x going in.
With less of a battery bank, the voltage needed going in is higher, so with two 6s you need to be near 75% SOC instead of 50% SOC as with four 6s.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
