joelmyer
Aug 08, 2014Explorer
Life and weather are keeping me off the roof.
I ordered 4x4x5 and 1x1x1 Aluminum angle so everything is inbound except the nuts, bolts screws and I can pick those up locally.
What is the "best" height for the panel? I will put holes at 3&1/2 inches in the 4x4 so I can either go above the rail or tilt. If I get the rail off then I could mount lower.
The controller will be mounted on a swing out panel so friends and I can watch the display at happy hour. Maybe I'll put Anderson Power Poles in the panel and battery leads so we can insert the watt meter and add that to the entertainment menu.
Joel
Joel
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
